A CPU abstract resource mapping model
is a tool to establish a throughput-based cost-model of a CPU. As a throughput-based model, dependencies between instructions are not taken into account. It builds on top of the idea of port mapping to perform an abstract resource mapping of a processor based on a wide variety of microbenchmarks, while remaining completely agnostic of the concrete CPU architecture, ISA, … Read about all the details here:
Research article (CGO'22) Extended version on ArXiV (no paywall)
Try it!
Our models are presented on this website in two ways: you can either look at the instructions tables, or play around with the model by throwing basic blocks of assembler in, and see what comes out.
See the tables Try the demo
Should you want to try out the tool yourself, the source code is also available for you to look at or play with.
Source code (Git repository)
Models
On this demo website, a few different mappings are available, varying on the architecture, CPU used, etc. Read more details about each mapping here: Mapping details
What it does, what it does not
aims at identifying the throughput-based performance bottleneck of a loop kernel, and as such, it is unable to detect latency-based performance bottlenecks. In other words, a kernel is treated as if there were no dependency between any two instructions and only the throughput of the used resources was taken into account. The kernel is also treated as if it were the body of an infinite (read: huge) loop running in steady-state.
In this abstraction, the CPU (not memory, nor cache) is modeled as a set of abstract resources. To be issued, an instruction must use (with a fixed ratio) some of those resources. This corresponds to what we call the abstract resource mapping which is a dual (conjunctive form) representation of the more known port mapping (disjunctive form) representation. Check the details here or in the research article.
Who are we?
is made by the CORSE Inria team. It is part of the PhD of Nicolas Derumigny and under the supervision of Fabrice Rastello. Other contributors include Théophile Bastian (PhD student at CORSE), Fabian Gruber (former PhD student at CORSE), and Christophe Guillon (engineer at STMicroelectronics).
Related projects
is not the only tool in its category! Here are a few other related projects:
